Multiplicity-induced-dominancy for delay systems: Comprehensive examples in the scalar neutral case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Control Année : 2023
This article focuses on the characterization of a particular spectral property called Multiplicity-induced-dominancy applying for linear dynamical systems described by delay-differential equations. More precisely, we characterize the property in the scalar neutral case with respect to the system parameters. Particular attention is paid to the so-called over-order multiplicities corresponding to real double and triple characteristic roots.
BBNT-2023-EJC.pdf (695.21 Ko) Télécharger le fichier
hal-04196450 , version 1 (05-09-2023)
Paternité
Amina Benarab, Islam Boussaada, Silviu-Iulian Niculescu, Karim Trabelsi. Multiplicity-induced-dominancy for delay systems: Comprehensive examples in the scalar neutral case. European Journal of Control, 2023, pp.100835. ⟨10.1016/j.ejcon.2023.100835⟩. ⟨hal-04196450⟩
64 Consultations
30 Téléchargements
