HFedSNN: Efficient Hierarchical Federated Learning using Spiking Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Federated Learning (FL) has emerged in edge computing to address privacy concerns in mobile networks. It allows the mobile devices to collaboratively train a model while keeping training data where they were generated. However, in practice, it suffers from several issues such as (i) robustness, due to a single point of failure, (ii) latency, as it requires a significant amount of communication resources, and (iii) convergence, due to system and statistical heterogeneity. To cope with these issues, Hierarchical FL (HFL) has been proposed as a promising alternative. HFL adds the edge servers as an intermediate layer for sub-model aggregation, several iterations will be performed before the global aggregation at the cloud server takes place, thus making the overall process more efficient, especially with non-independent and identically distributed (non-IID) data. Moreover, using traditional Artificial Neural Networks (ANNs) with HFL consumes a significant amount of energy, further hindering the application of decentralized FL on energy-constrained mobile devices. Therefore, this paper presents HFedSNN: an energy-efficient and fast-convergence model by incorporating Spike Neural Networks (SNNs) within HFL. SNN is a generation of neural networks, which promises tremendous energy and computation efficiency improvements. Taking advantage of HFL and SNN, numerical results demonstrate that HFedSNN outperforms FL with SNN (FedSNN) in terms of accuracy and communication overhead by 4.48% and 26×, respectively. Furthermore, HFedSNN significantly reduces energy consumption by 4.3× compared to FL with ANN (FedANN).
HFLSNN_Mobiwac23_hal.pdf (3.44 Mo) Télécharger le fichier
hal-04197115 , version 1 (05-09-2023)
Paternité
  • HAL Id : hal-04197115 , version 1
Ons Aouedi, Kandaraj Piamrat, Mario Südholt. HFedSNN: Efficient Hierarchical Federated Learning using Spiking Neural Networks. MobiWac 2023: 21st ACM International Symposium on Mobility Management and Wireless Access, Oct 2023, Montréal, Canada. ⟨hal-04197115⟩
189 Consultations
147 Téléchargements
