Prerequisite structure discovery for an intelligent tutoring system based on intrinsic motivation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2023
This paper addresses the importance of Knowledge Structure (KS) and Knowledge Tracing (KT) in improving the recommendation of educational content in intelligent tutoring systems. The KS represents the relations between different Knowledge Components (KCs), while KT predicts a learner's success based on her past history. The contribution of this research includes proposing a KT model that incorporates the KS as a learnable parameter, enabling the discovery of the underlying KS from learner trajectories. The quality of the uncovered KS is assessed by using it to recommend content and evaluating the recommendation algorithm with simulated students.
Prerequisite_structure_discovery_in_intelligent_tutoring_systems___IMOL2.pdf (332.36 Ko) Télécharger le fichier
hal-04201624 , version 1 (11-09-2023)
Paternité
  • HAL Id : hal-04201624 , version 1
Louis Annabi, Sao Mai Nguyen. Prerequisite structure discovery for an intelligent tutoring system based on intrinsic motivation. IMOL 2023 - The 6th Internatinal Workshop on Intrinsically Motivated Open-ended Learning, Sep 2023, Paris, France. ⟨hal-04201624⟩
88 Consultations
23 Téléchargements
