Discussions about high-quality embeddings on Quantum Annealers
Quantum Annealers (QA) such as D-Wave systems constitute a noisy implementation of the Adiabatic Quantum Computing process (AQC) and are used to find the ground state of an Ising problem. Qubit interconnections of a quantum chip are usually limited, and finding a good mapping of the Ising problem onto the quantum chip can be challenging. In fact, even defining what is a high-quality embedding is not trivial. After presenting a short review of existing embedding methods, we propose different experiments that could identify important criteria to consider while mapping problems on Quantum Annealers.
Informatique [cs]
Licence : CC BY ND - Paternité - Pas de modifications
