Integral representation formula for linear non-autonomous difference-delay equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This note states and proves an integral representation formula for the continuous solutions of a linear non-autonomous difference delay system in terms of the Lebesgue-Stieltjes integral depending on the initial data of the system. It gives a precise and correct statement of various formulations in the literature, and extends it to the time-varying case.
representation_formula.pdf (357.25 Ko) Télécharger le fichier
hal-04204500 , version 1 (12-09-2023)
hal-04204500 , version 2 (16-11-2023)
  • HAL Id : hal-04204500 , version 2
Laurent Baratchart, Sébastien Fueyo, Jean-Baptiste Pomet. Integral representation formula for linear non-autonomous difference-delay equations. 2023. ⟨hal-04204500v2⟩
43 Consultations
37 Téléchargements
