Good quantum low-density parity-check codes
This manuscript is a report of an internship done at INRIA on the subject of quantum error correction. In particular, some theoretical aspects of the quantum Tanner codes are explored such as the non-trivial logical operators bases, the number of logical qubits and the modified minimal distance when constructing the code from a Abelian group.
Licence : Domaine public
