Highly-Sensitive In Vitro Bioassays for FSH, TSH, PTH, Kp, and OT in Addition to LH in Mouse Leydig Tumor Cell - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Molecular Sciences Année : 2023
We demonstrate here that highly sensitive in vitro bioassays for FSH, TSH, and PTH can be set up in mouse Leydig Tumor Cells (mLTC), in addition to the normal LH/CG bioassay, after they were transfected with expression vectors encoding the corresponding Gs Protein-Coupled Receptors (GsPCR), such as FSHR, TSHR, or PTHR. Although the β2 adrenergic receptor is also a GsPCR, its expression in mLTC led to a significant but very low cAMP response compared to those observed with FSH, TSH, or PTH. Similarly, after transfection of the GiPCR MT1 melatonin receptor, we did not observe any inhibitory effect by melatonin of the LH or hCG stimulation. Interestingly, after transfection of mLTC with the human kisspeptin receptor (hKpR), which is a GqPCR, we observed a dose-dependent synergy of 10−12–10−7 M kisspeptin variants with a fixed concentration of 0.3 nM LH or hCG. Without any exogenous receptor transfection, a 2 h preincubation with OT or AVP led to a dose-dependent cAMP response to a fixed dose of LH or hCG. Therefore, highly sensitive in vitro bioassays for various hormones and other GPCR ligands can be set up in mLTC to measure circulating concentrations in only 3–10 µL of blood or other body fluids. Nevertheless, the development of an LHRKO mLTC cell line will be mandatory to obtain strict specificity for these bioassays to eliminate potential cross-reaction with LH or CG.
ijms-24-12047-v2.pdf (4.68 Mo) Télécharger le fichier
hal-04206799 , version 1 (02-10-2023)
Paternité
Danièle Klett, Lucie Pellissier, Didier Lomet, Flavie Derouin-Tochon, Vincent Robert, et al.. Highly-Sensitive In Vitro Bioassays for FSH, TSH, PTH, Kp, and OT in Addition to LH in Mouse Leydig Tumor Cell. International Journal of Molecular Sciences, 2023, 24 (15), pp.12047. ⟨10.3390/ijms241512047⟩. ⟨hal-04206799⟩
59 Consultations
22 Téléchargements
