Optimal quantization with branched optimal transport distances - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We consider the problem of optimal approximation of a target measure by an atomic measure with $N$ atoms, in branched optimal transport distance. This is a new branched transport version of optimal quantization problems. New difficulties arise, since in classical semi-discrete optimal transport with Wasserstein distance, the interfaces between cells associated with neighboring atoms have Voronoï structure and satisfy an explicit description. This description is missing for our problem, in which the cell interfaces are thought to have fractal boundary. We study the asymptotic behaviour of optimal quantizers for absolutely continuous measures as the number $N$ of atoms grows to infinity. We compute the limit distribution of the corresponding point clouds and show in particular a branched transport version of Zador's theorem. Moreover, we establish uniformity bounds of optimal quantizers in terms of separation distance and covering radius of the atoms, when the measure is $d$-Ahlfors regular. A crucial technical tool is the uniform in $N$ Hölder regularity of the landscape function, a branched transport analog to Kantorovich potentials in classical optimal transport.
branched_quantization_v1.pdf (748.84 Ko) Télécharger le fichier
hal-04208973 , version 1 (15-09-2023)
hal-04208973 , version 2 (08-02-2024)
Paternité
Paul Pegon, Mircea Petrache. Optimal quantization with branched optimal transport distances. 2023. ⟨hal-04208973v2⟩
100 Consultations
35 Téléchargements
