Convergence Results for Primal-Dual Algorithms in the Presence of Adjoint Mismatch - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SIAM Journal on Imaging Sciences Année : 2023
Most optimization problems arising in imaging science involve high-dimensional linear operators and their adjoints. In the implementations of these operators, changes may be introduced for various practical considerations (e.g., memory limitation, computational cost, convergence speed), leading to an adjoint mismatch. This occurs for the X-ray tomographic inverse problems found in Computed Tomography (CT), where a surrogate operator often replaces the adjoint of the measurement operator (called projector). The resulting adjoint mismatch can jeopardize the convergence properties of iterative schemes used for image recovery. In this paper, we study the theoretical behavior of a panel of primal-dual proximal algorithms, which rely on forward-backward-(forward) splitting schemes when an adjoint mismatch occurs. We analyze these algorithms by focusing on the resolution of possibly non-smooth convex penalized minimization problems in an infinite-dimensional setting. Using tools from fixed point theory, we show that they can solve monotone inclusions beyond minimization problems. Such findings indicate these algorithms can be seen as a generalization of classical primal-dual formulations. The applicability of our findings is also demonstrated through two numerical experiments in the context of CT image reconstruction.
Adjoint_Mismatch_AndresC.pdf (1.32 Mo) Télécharger le fichier
hal-04210972 , version 1 (28-04-2022)
hal-04210972 , version 2 (19-09-2023)
Paternité
Emilie Chouzenoux, Andrés Contreras, Jean-Christophe Pesquet, M. Savanier. Convergence Results for Primal-Dual Algorithms in the Presence of Adjoint Mismatch. SIAM Journal on Imaging Sciences, 2023, 16 (1), pp.1-34. ⟨10.1137/22M1490223⟩. ⟨hal-04210972v2⟩
203 Consultations
207 Téléchargements
