Interpolation of Point Distributions for Digital Stippling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We present a new way to merge any two point distribution approaches using distance fields. Our new process allows us to produce digital stippling that fills areas with stipple dots without visual artifacts as well as includes clear linear features without fussiness. Our merging thus benefits from past work that can optimize for either goal individually, yet typically by sacrificing the other. The new possibility of combining any two distributions using different distance field functions and their parameters also allows us to produce a vast range of stippling styles, which we demonstrate as well.
2307.00938.pdf (4.79 Mo) Télécharger le fichier
Format : Figure, Image
hal-04212086 , version 1 (20-09-2023)
Paternité
Germán Arroyo, Domingo Martín, Tobias Isenberg. Interpolation of Point Distributions for Digital Stippling. 2023. ⟨hal-04212086⟩
61 Consultations
10 Téléchargements
