Energy-aware mapping and scheduling strategies for real-time workflows under reliability constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Parallel and Distributed Computing Année : 2023
Tri-criteria mapping and scheduling problem (energy, deadline, reliability) for real-time workflows of arbitrary shape • Research highlight 2: First general solution without any limitation on the number of replicas used to match the reliability threshold of each task • Research highlight 3: Innovative solution based upon layers of the workflow graph outperforms competitors from the literature
jpdc-final.pdf (374.95 Ko) Télécharger le fichier
hal-04214810 , version 1 (22-09-2023)
Paternité
Zhiwei Wu, Li Han, Jing Liu, Yves Robert, Frédéric Vivien. Energy-aware mapping and scheduling strategies for real-time workflows under reliability constraints. Journal of Parallel and Distributed Computing, 2023, 176, pp.1-16. ⟨10.1016/j.jpdc.2023.02.004⟩. ⟨hal-04214810⟩
27 Consultations
30 Téléchargements
