Interactive and Concentrated Differential Privacy for Bandits - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bandits play a crucial role in interactive learning schemes and modern recommender systems. However, these systems often rely on sensitive user data, making privacy a critical concern. This paper investigates privacy in bandits with a trusted centralized decision-maker through the lens of interactive Differential Privacy (DP). While bandits under pure $\epsilon$-global DP have been well-studied, we contribute to the understanding of bandits under zero Concentrated DP (zCDP). We provide minimax and problem-dependent lower bounds on regret for finite-armed and linear bandits, which quantify the cost of $\rho$-global zCDP in these settings. These lower bounds reveal two hardness regimes based on the privacy budget $\rho$ and suggest that $\rho$-global zCDP incurs less regret than pure $\epsilon$-global DP. We propose two $\rho$-global zCDP bandit algorithms, AdaC-UCB and AdaC-GOPE, for finite-armed and linear bandits respectively. Both algorithms use a common recipe of Gaussian mechanism and adaptive episodes. We analyze the regret of these algorithms to show that AdaC-UCB achieves the problem-dependent regret lower bound up to multiplicative constants, while AdaC-GOPE achieves the minimax regret lower bound up to poly-logarithmic factors. Finally, we provide experimental validation of our theoretical results under different settings.
hal-04215685 , version 1 (22-09-2023)
Paternité - Pas d'utilisation commerciale
Achraf Azize, Debabrota Basu. Interactive and Concentrated Differential Privacy for Bandits. EWRL 2023 – European Workshop on Reinforcement Learning, Sep 2023, Brussels (Belgium), Belgium. ⟨hal-04215685⟩
33 Consultations
0 Téléchargements
