Implications of Physical Fault Injections on Single Chip Motes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Single-chip motes are wireless sensor nodes that integrate computation, communication, power and sensing on a single chip. We consider the security threats these novel devices are subject to when employed in safety-critical applications. Fault injection attacks are a prominent form of physical attacks that pose a threat to the normal and secure functioning of targeted devices, potentially compromising their intended behavior. These attacks have been studied mainly on commercial off-the-shelf devices which rely on external components such as crystal oscillators and passives. Such external components are absent from single-chip motes, resulting in a uniquely different attack surface compared to commercial systems. In this paper, we first survey the features of the common fault injection methods, and then study and compare their implications on single-chip motes.
faour23implications.pdf (1.52 Mo) Télécharger le fichier
hal-04216977 , version 1 (03-10-2023)
Paternité
  • HAL Id : hal-04216977 , version 1
Sara Faour, Mališa Vučinić, Filip Maksimovic, David Burnett, Paul Mühlethaler, et al.. Implications of Physical Fault Injections on Single Chip Motes. IEEE World Forum on Internet of Things, Oct 2023, Aveiro, Portugal. ⟨hal-04216977⟩
Collections
INRIA INRIA2 SPRES
86 Consultations
101 Téléchargements
