Reconstruction of obstacles in a Stokes flow as a shape-from-moments problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
We address the classical inverse problem of recovering the position and shape of obstacles immersed in a planar Stokes flow using boundary measurements. We prove that this problem can be transformed into a shape-from-moments problem to which ad hoc reconstruction methods can be applied. The effectiveness of this approach is confirmed by numerical tests that show significant improvements over those available in the literature to date.
Stokes_prony_ArXiv (1).pdf (1.22 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-04218495 , version 1 (26-09-2023)
Alexandre Munnier. Reconstruction of obstacles in a Stokes flow as a shape-from-moments problem. 2023. ⟨hal-04218495⟩
15 Consultations
8 Téléchargements
