Synchronizing words under LTL constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information Processing Letters Année : 2023
Synchronizing a (deterministic, finite-state) automaton is the problem of finding a sequence of actions to be played in the automaton in order to end up in the same state independently of the starting state. We consider synchronization with LTL constraints on the executions leading to synchronization, extending the results of [Petra Wolf. Synchronization under dynamic constraints. FSTTCS'20] by showing that the problem is PSPACE-complete for LTL as well as for restricted fragments (involving only modality F or G), while it is NP-complete for constraints expressed using only modality X.
ipl182()-BFM.pdf (387.66 Ko) Télécharger le fichier
hal-04219120 , version 1 (26-09-2023)
Paternité
Nathalie Bertrand, Hugo Francon, Nicolas Markey. Synchronizing words under LTL constraints. Information Processing Letters, 2023, 182, pp.106392. ⟨10.1016/j.ipl.2023.106392⟩. ⟨hal-04219120⟩
18 Consultations
19 Téléchargements
