Scattered wavefield in the stochastic homogenization regime - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In the context of providing a mathematical framework for the propagation of ultrasound waves in a random multiscale medium, we consider the scattering of classical waves (modeled by a divergence form scalar Helmholtz equation) by a bounded object with a random composite micro-structure embedded in an unbounded homogeneous background medium. Using quantitative stochastic homogenization techniques, we provide asymptotic expansions of the scattered field in the background medium with respect to a scaling parameter describing the spatial random oscillations of the micro-structure. Introducing a boundary layer corrector to compensate the breakdown of stationarity assumptions at the boundary of the scattering medium, we prove quantitative $L^2$- and $H^1$- error estimates for the asymptotic first-order expansion. The theoretical results are supported by numerical experiments.
Article1.pdf (18.19 Mo) Télécharger le fichier
hal-04220919 , version 1 (28-09-2023)
Josselin Garnier, Laure Giovangigli, Quentin Goepfert, Pierre Millien. Scattered wavefield in the stochastic homogenization regime. 2023. ⟨hal-04220919⟩
67 Consultations
2 Téléchargements
