Descriptive complexity of topological invariants - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this article, we investigate the descriptive complexity of topological invariants. Our main goal is to understand the expressive power of low complexity invariants, by investigating which spaces they can distinguish. We study the invariants in the first two levels of the Borel hierarchy. We develop techniques to establish whether two spaces can be separated by invariants in these levels. We show that they are sufficient to separate finite topological graphs. We finally identify the complexity of recognizing the line segment.
preprint.pdf (365.67 Ko) Télécharger le fichier
hal-04222391 , version 1 (29-09-2023)
Paternité
  • HAL Id : hal-04222391 , version 1
Djamel Eddine Amir, Mathieu Hoyrup. Descriptive complexity of topological invariants. 2023. ⟨hal-04222391⟩
47 Consultations
43 Téléchargements
