A class of symmetric-hyperbolic PDEs modelling fluid and solid continua - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Proceedings and Surveys Année : 2023
We generalize a new symmetric-hyperbolic system of PDEs proposed in [ESAIM:M2AN 55 (2021) 807-831] for Maxwell fluids to a class of systems that define unequivocally multi-dimensional visco-elastic flows. Precisely, within a general setting for continuum mechanics, we specify constitutive assumptions i) that ensure the unequivocal definition of motions satisfying widely-admitted physical principles, and ii) that contain [ESAIM:M2AN 55 (2021) 807-831] as one particular realization of those assumptions. The new class can capture the mechanics of various materials, from solids to viscous fluids, possibly with temperature dependence and heat conduction.
constitutive.pdf (438.38 Ko) Télécharger le fichier
hal-04223434 , version 1 (03-10-2023)
  • HAL Id : hal-04223434 , version 1
Sébastien Boyaval. A class of symmetric-hyperbolic PDEs modelling fluid and solid continua. ESAIM: Proceedings and Surveys, In press. ⟨hal-04223434⟩
69 Consultations
46 Téléchargements
