Porting Coq Scripts to the Mathematical Components Library Version 2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2023
The Mathematical Components library (hereafter, MathComp) provides, among others, a number of mathematical structures organized as hierarchies. Hierarchy Builder (hereafter, HB) is an extension of the Coq proof assistant to ease the development of hierarchies of structures. MathComp 2 is the result of the port of MathComp to HB. This document is a technical report whose goal is to explain how to port MathComp developments to MathComp 2. It has been written by the participants of the MathComp Documentation Sprint that happened from 2023-05-03 to 2023-05-10.
porting.pdf (333.31 Ko) Télécharger le fichier
hal-04225130 , version 1 (02-10-2023)
Paternité
  • HAL Id : hal-04225130 , version 1
Reynald Affeldt, Yves Bertot, Cyril Cohen, Pierre Roux, Kazuhiko Sakaguchi, et al.. Porting Coq Scripts to the Mathematical Components Library Version 2. Inria Sophia Antipolis - Méditerranée, Université Côte d'Azur; National Institute of Advanced Industrial Science and Technology (AIST), Japan; ONERA / DTIS, Université de Toulouse, France. 2023, pp.1-12. ⟨hal-04225130⟩
52 Consultations
45 Téléchargements
