Optimal Transport with Adaptive Regularisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Regularising the primal formulation of optimal transport (OT) with a strictly convex term leads to enhanced numerical complexity and a denser transport plan. Many formulations impose a global constraint on the transport plan, for instance by relying on entropic regularisation. As it is more expensive to diffuse mass for outlier points compared to central ones, this typically results in a significant imbalance in the way mass is spread across the points. This can be detrimental for some applications where a minimum of smoothing is required per point. To remedy this, we introduce OT with Adaptive RegularIsation (OTARI), a new formulation of OT that imposes constraints on the mass going in or/and out of each point. We then showcase the benefits of this approach for domain adaptation.
workshop_paper.pdf (1.39 Mo) Télécharger le fichier
hal-04229636 , version 1 (05-10-2023)
Hugues Van Assel, Titouan Vayer, Remi Flamary, Nicolas Courty. Optimal Transport with Adaptive Regularisation. NeurIPS OTML Workshop, Dec 2023, New Orleans, France. ⟨hal-04229636⟩
86 Consultations
164 Téléchargements
