Broadcast Channel Coding: Algorithmic Aspects and Non-Signaling Assistance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We address the problem of coding for classical broadcast channels, which entails maximizing the success probability that can be achieved by sending a xed number of messages over a broadcast channel. For point-to-point channels, Barman and Fawzi found in [1] a (1−e −1)-approximation algorithm running in polynomial time, and showed that it is NP-hard to achieve a strictly better approximation ratio. Furthermore, these algorithmic results were at the core of the limitations they established on the power of non-signaling assistance for point-to-point channels. It is natural to ask if similar results hold for broadcast channels, exploiting links between approximation algorithms of the channel coding problem and the non-signaling assisted capacity region. In this work, we make several contributions on algorithmic aspects and non-signaling assisted capacity regions of broadcast channels. For the class of deterministic broadcast channels, we describe a (1 − e −1) 2-approximation algorithm running in polynomial time, and we show that the capacity region for that class is the same with or without non-signaling assistance. Finally, we show that in the value query model, we cannot achieve a better approximation ratio than Ω 1 √ m in polynomial time for the general broadcast channel coding problem, with m the size of one of the outputs of the channel.
Broadcast.pdf (431.21 Ko) Télécharger le fichier
hal-04232851 , version 1 (09-10-2023)
Paternité
  • HAL Id : hal-04232851 , version 1
Omar Fawzi, Paul Fermé. Broadcast Channel Coding: Algorithmic Aspects and Non-Signaling Assistance. 2023. ⟨hal-04232851⟩
12 Consultations
24 Téléchargements
