A Stochastic Analysis of Particle Systems with Pairing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Motivated by a general principle governing regulation mechanisms in biological cells, we investigate a general interaction scheme between different populations of particles and specific particles, referred to as agents. Assuming that each particle follows a random path in the medium, when a particle and an agent meet, they may bind and form a pair which has some specific functional properties. Such a pair is also subject to random events and it splits after some random amount of time. In a stochastic context, using a Markovian model for the vector of the number of paired particles, and by taking the total number of particles as a scaling parameter, we study the asymptotic behavior of the time evolution of the number of paired particles. Two scenarios are investigated: one with a large but fixed number of agents, and the other one, the dynamic case, when agents are created at a bounded rate and may die after some time when they are not paired. A first order limit theorem is established for the time evolution of the system in both cases. The proof of an averaging principle of the dynamic case is one of the main contributions of the paper. Limit theorems for fluctuations are obtained in the case of a fixed number agents. The impact of dynamical arrivals of agents on the level of pairing of the system is discussed.
hal-04234301 , version 1 (10-10-2023)
Paternité
Vincent Fromion, Philippe Robert, Jana Zaherddine. A Stochastic Analysis of Particle Systems with Pairing. 2023. ⟨hal-04234301⟩
28 Consultations
0 Téléchargements
