Aggregated f -average Neural Network for Interpretable Ensembling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Ensemble learning leverages multiple models (i.e., weak learners) on a common machine learning task to enhance prediction performance. Basic ensembling approaches average the weak learners outputs, while more sophisticated ones stack a machine learning model in between the weak learners outputs and the final prediction. This work fuses both aforementioned frameworks. We introduce an aggregated f-average (AFA) shallow neural network which models and combines different types of averages to perform an optimal aggregation of the weak learners predictions. We emphasise its interpretable architecture and simple training strategy, and illustrate its good performance on the problem of few-shot class incremental learning.
favg_tnnls.pdf (316.65 Ko) Télécharger le fichier
hal-04237149 , version 1 (11-10-2023)
hal-04237149 , version 2 (12-12-2023)
Paternité
Mathieu Vu, Emilie Chouzenoux, Jean-Christophe Pesquet, Ismail Ben Ayed. Aggregated f -average Neural Network for Interpretable Ensembling. 2023. ⟨hal-04237149v2⟩
22 Consultations
13 Téléchargements
