Maximal Martingale Wasserstein Inequality - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In this note, we complete the analysis of the Martingale Wasserstein Inequality started in [5] by checking that this inequality fails in dimension d ≥ 2 when the integrability parameter ρ belongs to [1, 2) while a stronger Maximal Martingale Wasserstein Inequality holds whatever the dimension d when ρ ≥ 2.
main.pdf (361.17 Ko) Télécharger le fichier
hal-04241070 , version 1 (13-10-2023)
Benjamin Jourdain, Kexin Shao. Maximal Martingale Wasserstein Inequality. 2023. ⟨hal-04241070⟩
29 Consultations
10 Téléchargements
