Inter-regional correlation estimators for functional magnetic resonance imaging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2023
Functional magnetic resonance imaging (fMRI) functional connectivity between brain regions is often computed using parcellations defined by functional or structural atlases. Typically, some kind of voxel averaging is performed to obtain a single temporal correlation estimate per region pair. However, several estimators can be defined for this task, with various assumptions and degrees of robustness to local noise, global noise, and region size. In this paper, we systematically present and study the properties of 9 different functional connectivity estimators taking into account the spatial structure of fMRI data, based on a simple fMRI data spatial model. These include 3 existing estimators and 6 novel estimators. We demonstrate the empirical properties of the estimators using synthetic, animal, and human data, in terms of graph structure, repeatability and reproducibility, discriminability, dependence on region size, as well as local and global noise robustness.
inter_correlation_estimators(28).pdf (6.72 Mo) Télécharger le fichier
hal-04242995 , version 1 (15-10-2023)
Paternité
Sophie Achard, Jean-François Coeurjolly, Pierre Lafaye de Micheaux, Hanâ Lbath, Jonas Richiardi. Inter-regional correlation estimators for functional magnetic resonance imaging. NeuroImage, 2023, 282, pp.120388. ⟨10.1016/j.neuroimage.2023.120388⟩. ⟨hal-04242995⟩
57 Consultations
13 Téléchargements
