Elbow trauma in children: development and evaluation of radiological artificial intelligence models
Rationale and Objectives: To develop a model using artificial intelligence (A.I.) able to detect post-traumatic injuries on pediatric elbow X-rays then to evaluate its performances in silico and its impact on radiologists' interpretation in clinical practice. Material and Methods: A total of 1956 pediatric elbow radiographs performed following a trauma were retrospectively collected from 935 patients aged between 0 and 18 years. Deep convolutional neural networks were trained on these X-rays. The two best models were selected then evaluated on an external test set involving 120 patients, whose X-rays were performed on a different radiological equipment in another time period. Eight radiologists interpreted this external test set without then with the help of the A.I. models. Results: Two models stood out: model 1 had an accuracy of 95.8% and an AUROC of 0.983 and model 2 had an accuracy of 90.5% and an AUROC of 0.975. On the external test set, model 1 kept a good accuracy of 82.5% and AUROC of 0.916 while model 2 had a loss of accuracy down to 69.2% and of AUROC to 0.793. Model 1 significantly improved radiologist's sensitivity (0.82 to 0.88, P = 0.016) and accuracy (0.86 to 0.88, P = 0,047) while model 2 significantly decreased specificity of readers (0.86 to 0.83, P = 0.031). Conclusion: End-to-end development of a deep learning model to assess post-traumatic injuries on elbow Xray in children was feasible and showed that models with close metrics in silico can unpredictably lead radiologists to either improve or lower their performances in clinical settings.
