Sensor placement optimal for the precision of modal parameter estimation with subspace methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we focus on sensor placement for output-only modal analysis, where the objective is to choose those sensor locations yielding a minimal variance in the identification of modal parameters from measurement data. It is heuristically shown that the variance of modal parameters estimated with data-driven subspace identification can be approximated solely based on the process and the measurement noise properties with the Kalman filter and the underlying system model, and is independent of data which are not available at the experimental design stage. The performance of the proposed approach is illustrated on an extensive Monte Carlo simulation for an illustrative example of a mechanical chain system
paper_eurodyn.pdf (1.37 Mo) Télécharger le fichier
hal-04249271 , version 1 (19-10-2023)
Paternité
  • HAL Id : hal-04249271 , version 1
Szymon Gres, Michael Döhler, Vasilis K. Dertimanis, Eleni Chatzi. Sensor placement optimal for the precision of modal parameter estimation with subspace methods. EURODYN 2023 - 12th International Conference on Structural Dynamics, Jul 2023, Delft, Netherlands. pp.1-10. ⟨hal-04249271⟩
20 Consultations
17 Téléchargements
