Pursuing Shtuck - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Pursuing Shtuck
By mimicking the internal sheafification construction in an arbitrary topos, we provide a simple description of the various sheaf-related constructions in a purely type-theoretical setting. Assuming mild extensionality properties on our target type theory, we show that it almost results in a syntactic model of CIC. Unfortunately, a well-known topos-theoretic issue carries over, and the resulting theory, called ShTT, does not feature universes. We propose three different solutions to this problem: making the target theory univalent, allowing effects in the source theory, or changing our point of view while using strict propositions. As a side-product, we also give a computational interpretation of sheaves that highlights their deep relationship with the well-known structure of interaction trees.
main.pdf (639.1 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-04251754 , version 1 (20-10-2023)
Paternité
  • HAL Id : hal-04251754 , version 1
Pierre-Marie Pédrot. Pursuing Shtuck. 2023. ⟨hal-04251754⟩
48 Consultations
66 Téléchargements
