From FMTV to WATERS: Lessons Learned from the First Verification Challenge at ECRTS (Artifact) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Dagstuhl Artifacts Series Année : 2023
Étienne André
Loïc Fejoz
  • Fonction : Auteur
Susanne Graf
Youcheng Sun
We propose here solutions to the FMTV 2015 challenge of a distributed video processing system using four different formalisms, as well as the description of the challenge itself. This artifact contains several solutions to various subchallenges, and instructions and scripts to reproduce these results smoothly.
DARTS.9.1.4.pdf (599.18 Ko) Télécharger le fichier
hal-04254710 , version 1 (05-04-2024)
Paternité
Sebastian Altmeyer, Étienne André, Silvano Dal Zilio, Loïc Fejoz, Michael González Harbour, et al.. From FMTV to WATERS: Lessons Learned from the First Verification Challenge at ECRTS (Artifact). Dagstuhl Artifacts Series, 2023, 9 (1), ⟨10.4230/DARTS.9.1.4⟩. ⟨hal-04254710⟩
82 Consultations
3 Téléchargements
