While Loops in Coq - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
While Loops in Coq
While loops are present in virtually all imperative programming languages. They are important both for practical reasons (performing a number of iterations not known in advance) and theoretical reasons (achieving Turing completeness). In this paper we propose an approach for incorporating while loops in an imperative language shallowly embedded in the Coq proof assistant. The main difficulty is that proving the termination of while loops is nontrivial, or impossible in the case of nontermination, whereas Coq only accepts programs endowed with termination proofs. Our solution is based on a new, general method for defining possibly non-terminating recursive functions in Coq. We illustrate the approach by proving termination and partial correctness of a program on linked lists.
paper.pdf (148.23 Ko) Télécharger le fichier
hal-04254872 , version 1 (23-10-2023)
Paternité
David Nowak, Vlad Rusu. While Loops in Coq. 7th Symposium on Working Formal Methods (FROM 2023), Sep 2023, Bucarest, Romania. pp.96 - 109, ⟨10.4204/eptcs.389.8⟩. ⟨hal-04254872⟩
61 Consultations
9 Téléchargements
