Explainable prediction of Qcodes for NOTAMs using column generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of the Operational Research Society Année : 2023
A NOtice To AirMen (NOTAM) contains important flight route related information. To search and filter them, NOTAMs are grouped into categories called QCodes. In this paper, we develop a tool to predict, with some explanations, a Qcode for a NOTAM. We present a way to extend the interpretable binary classification using column generation proposed in Dash, Gunluk, and Wei (2018) to a multiclass text classification method. We describe the techniques used to tackle the issues related to one-vs-rest classification, such as multiple outputs and class imbalances. Furthermore, we introduce some heuristics, including the use of a CP-SAT solver for the subproblems, to reduce the training time. Finally, we show that our approach compares favorably with state-of-the-art machine learning algorithms like Linear SVM and small neural networks while adding the needed interpretability component.
hal-04255231 , version 1 (23-10-2023)
Krunal Kishor Patel, Guy Desaulniers, Andrea Lodi, Freddy Lecue. Explainable prediction of Qcodes for NOTAMs using column generation. Journal of the Operational Research Society, 2023, pp.1-11. ⟨10.1080/01605682.2023.2181715⟩. ⟨hal-04255231⟩
38 Consultations
0 Téléchargements
