Quantum Linear Key-Recovery Attacks Using the QFT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Quantum Fourier Transform is a fundamental tool in quantum cryptanalysis. In symmetric cryptanalysis, hidden shift algorithms such as Simon's, which rely on the QFT, have been used to obtain structural attacks on some very specific block ciphers. The Fourier Transform is also used in classical cryptanalysis, for example in FFT-based linear key-recovery attacks introduced by Collard et al. (ICISC 2007). Whether such techniques can be adapted to the quantum setting has remained so far an open question. In this paper, we introduce a new framework for quantum linear keyrecovery attacks using the QFT. These attacks loosely follow the classical method of Collard et al., in that they rely on the fast computation of a correlation state in which experimental correlations, rather than being directly accessible, are encoded in the amplitudes of a quantum state. The experimental correlation is a statistic that is expected to be higher for the good key, and on some conditions, the increased amplitude creates a speedup with respect to an exhaustive search of the key. The same method also yields a new family of structural attacks, and new examples of quantum speedups beyond quadratic using classical known-plaintext queries.
main.pdf (632.07 Ko) Télécharger le fichier
Licence : CC BY - Paternité
hal-04260886 , version 1 (26-10-2023)
Paternité
André Schrottenloher. Quantum Linear Key-Recovery Attacks Using the QFT. CRYPTO 2023 - 43rd International Cryptology Conference, Aug 2023, Santa Barbara, CA, United States. pp.258-291, ⟨10.1007/978-3-031-38554-4_9⟩. ⟨hal-04260886⟩
31 Consultations
17 Téléchargements
