Expanding bipartite Bell inequalities for maximum multi-partite randomness
Nonlocal tests on multipartite quantum correlations form the basis of protocols that certify randomness in a device-independent (DI) way. Such correlations admit a rich structure, making the task of choosing an appropriate test difficult. For example, extremal Bell inequalities are tight witnesses of nonlocality, however achieving their maximum violation places constraints on the underlying quantum system, which can reduce the rate of randomness generation. As a result there is often a trade-off between maximum randomness and the amount of violation of a given Bell inequality. Here, we explore this trade-off for more than two parties. More precisely, we study the maximum amount of randomness that can be certified by correlations exhibiting a violation of the Mermin-Ardehali-Belinskii-Klyshko (MABK) inequality. We find that maximum quantum violation and maximum randomness are incompatible for any even number of parties, with incompatibility diminishing as the number of parties grow, and conjecture the precise trade-off. We also show that maximum MABK violation is not necessary for maximum randomness for odd numbers of parties. To obtain our results, we derive new families of Bell inequalities certifying maximum randomness from a technique for randomness certification, which we call "expanding Bell inequalities". Our technique allows one to take a bipartite Bell expression, known as the seed, and transform it into a multipartite Bell inequality tailored for randomness certification, showing how intuition learned in the bipartite case can find use in more complex scenarios.
