Type-directed Program Transformation for Constant-Time Enforcement
Constant-time is a programming discipline which protects security sensitive code against a wide class of timing attacks. This discipline can be formalised as a non-interference property and enforced by an information flow type system which prevents branching and memory accesses over secret data. We propose a relaxed information flow type system which tracks indirect flows but only rejects programs leaking secrets through direct flows. The main result of this paper is that any program that is accepted using this relaxed type system can be transformed automatically into a semantically equivalent constant-time program. Our algorithms are implemented in the jasmin compiler and validated against synthetic programs.
Domains
Computer Science [cs]
