A single domain intrabody targeting the follicle-stimulating hormone receptor (FSHR) impacts FSH-induced G protein-dependent signalling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue FEBS Letters Année : 2023
Asuka Inoue
  • Fonction : Auteur
  • PersonId : 1303066
Intracellular variable fragments from heavy-chain antibody from camelids (intra-VHH) have been successfully used as chaperones to solve the 3D structure of active G protein-coupled receptors bound to their transducers. However, their effect on signalling has been poorly explored, although they may provide a better understanding on the relationships between receptor conformation and activity. Here, we isolated and characterized iPRC1, the first intra-VHH recognizing a member of the large glycoprotein hormone receptors family, the follicle-stimulating hormone receptor (FSHR). This intra-VHH recognizes the FSHR 3 rd intracellular loop and decreases cAMP production in response to FSH, without altering Gαs recruitment. Hence, iPRC1 behaves as an allosteric modulator and provides a new tool to complete structure/activity studies performed so far on this receptor.
RaynaudManuscript-R2-BioRxiv.pdf (2.62 Mo) Télécharger le fichier
Licence : CC BY NC ND - Paternité - Pas d'utilisation commerciale - Pas de modification
hal-04269864 , version 1 (03-11-2023)
Paternité
Pauline Raynaud, Vinesh Jugnarain, Océane Vaugrente, Amandine Vallet, Thomas Boulo, et al.. A single domain intrabody targeting the follicle-stimulating hormone receptor (FSHR) impacts FSH-induced G protein-dependent signalling. FEBS Letters, 2023, 598 (2), pp.220-232. ⟨10.1002/1873-3468.14765⟩. ⟨hal-04269864⟩
92 Consultations
17 Téléchargements
