HairSplitter: separating similar strains in metagenome assembly - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2023
Similar regions (typically different strains) get collapsed in a single sequence during genome assembly. HairSplitter separates the collapsed regions to obtain the phased, complete assembly, regardless of the number of haplotypes present and their coverage.
Faure-Roland-Genscale-ISMBECCB2023.pdf (338.2 Ko) Télécharger le fichier
hal-04272480 , version 1 (06-11-2023)
Paternité
  • HAL Id : hal-04272480 , version 1
Roland Faure, Jean-François Flot, Dominique Lavenier. HairSplitter: separating similar strains in metagenome assembly. ISMB/ECCB 2023 - 31st Annual Intelligent Systems For Molecular Biology and the 22nd Annual European Conference on Computational Biology, Jul 2023, Lyon, France. pp.1-1, 2023. ⟨hal-04272480⟩
45 Consultations
29 Téléchargements
