The 2T -qutrit, a two-mode bosonic qutrit - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Quantum Année : 2023
Quantum computers often manipulate physical qubits encoded on twolevel quantum systems. Bosonic qubit codes depart from this idea by encoding information in a well-chosen subspace of an infinite-dimensional Fock space. This larger physical space provides a natural protection against experimental imperfections and allows bosonic codes to circumvent no-go results that apply to states constrained by a 2-dimensional Hilbert space. A bosonic qubit is usually defined in a single bosonic mode but it makes sense to look for multimode versions that could exhibit better performance. In this work, building on the observation that the cat code lives in the span of coherent states indexed by a finite subgroup of the complex numbers, we consider a two-mode generalisation living in the span of 24 coherent states indexed by the binary tetrahedral group 2T of the quaternions. The resulting 2T-qutrit naturally inherits the algebraic properties of the group 2T and appears to be quite robust in the low-loss regime. We initiate its study and identify stabilisers as well as some logical operators for this bosonic code.
q-2023-06-05-1032.pdf (780.5 Ko) Télécharger le fichier
hal-04277372 , version 1 (09-11-2023)
Paternité
Aurélie Denys, Anthony Leverrier. The 2T -qutrit, a two-mode bosonic qutrit. Quantum, 2023, 7, pp.1032. ⟨10.22331/q-2023-06-05-1032⟩. ⟨hal-04277372⟩
Collections
INRIA INRIA2 ANR
13 Consultations
7 Téléchargements
