Skeleton Disk-Graph Roadmap: A Sparse Deterministic Roadmap For Safe 2D Navigation and Exploration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Robotics and Automation Letters Année : 2024
In this letter, we describe a novel roadmap construction method in unknown environments, which relies on the extraction of the Hamilton-Jacobi skeleton of the free space. This skeleton is used to construct a graph of free-space bubbles, effectively compressing the skeleton information in a sparse data structure but retaining its topology. The bubbles also enforce safety directly in the roadmap structure. We first demonstrate the relevance of this approach for standard path-planning tasks. We also propose a frontiers-based exploration strategy able to autonomously and safely build a complete 2D map of the environment.
2023_ral_noel.pdf (4.45 Mo) Télécharger le fichier
hal-04282634 , version 1 (13-11-2023)
Paternité
Thibault Noël, Antoine Lehuger, Eric Marchand, François Chaumette. Skeleton Disk-Graph Roadmap: A Sparse Deterministic Roadmap For Safe 2D Navigation and Exploration. IEEE Robotics and Automation Letters, 2024, 9 (1), pp.555-562. ⟨10.1109/LRA.2023.3334103⟩. ⟨hal-04282634⟩
61 Consultations
44 Téléchargements
