A Practical Algorithm for Volume Estimation based on Billiard Trajectories and Simulated Annealing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Journal of Experimental Algorithmics Année : 2023
We tackle the problem of efficiently approximating the volume of convex polytopes, when these are given in three different representations: H-polytopes, which have been studied extensively, V-polytopes, and zonotopes (Z-polytopes). We design a novel practical Multiphase Monte Carlo algorithm that leverages random walks based on billiard trajectories, as well as a new empirical convergence test and a simulated annealing schedule of adaptive convex bodies. After tuning several parameters of our proposed method, we present a detailed experimental evaluation of our tuned algorithm using a rich dataset containing Birkhoff polytopes and polytopes from structural biology. Our open-source implementation tackles problems that have been intractable so far, offering the first software to scale up in thousands of dimensions for H-polytopes and in the hundreds for V- and Z-polytopes on moderate hardware. Last, we illustrate our software in evaluating Z-polytope approximations.
Mots clés
hal-04294298 , version 1 (19-11-2023)
Apostolos Chalkis, Ioannis Z. Emiris, Vissarion Fisikopoulos. A Practical Algorithm for Volume Estimation based on Billiard Trajectories and Simulated Annealing. ACM Journal of Experimental Algorithmics, 2023, 28, pp.1-34. ⟨10.1145/3584182⟩. ⟨hal-04294298⟩
16 Consultations
0 Téléchargements
