Short Voting Codes For Practical Code Voting
To preserve voter secrecy on untrusted voter devices we propose to use short voting codes. This ensures voting codes remain practical even if the voter is able to select multiple voting choices. We embed the mechanism in a protocol that avoids complex cryptography in both the setup and the voting phase and relies only on standard cryptographic primitives. Trusting the setup, and one out of multiple server components, the protocol provides vote secrecy, cast-as-intended, recorded-as-cast, tallied-as-recorded, eligibility and universal verifiability.
Cryptographie et sécurité [cs.CR]
Licence : CC BY - Paternité
