Extending a High-Performance Prover to Higher-Order Logic - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Abstract Most users of proof assistants want more proof automation. Some proof assistants discharge goals by translating them to first-order logic and invoking an efficient prover on them, but much is lost in translation. Instead, we propose to extend first-order provers with native support for higher-order features. Building on our extension of E to $$\lambda $$ -free higher-order logic, we extend E to full higher-order logic. The result is the strongest prover on benchmarks exported from a proof assistant.
conf.pdf (499.45 Ko) Télécharger le fichier
hal-04298635 , version 1 (21-11-2023)
Paternité
Petar Vukmirović, Jasmin Blanchette, Stephan Schulz. Extending a High-Performance Prover to Higher-Order Logic. TACAS 2023, 2023, Paris, France. pp.111-129, ⟨10.1007/978-3-031-30820-8_10⟩. ⟨hal-04298635⟩
21 Consultations
4 Téléchargements
