Towards a generic theoretical framework for pattern-based LUCC modeling: Allocation revisited: Formal foundations and bias identification - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Environmental Modelling and Software Année : 2023
An allocation bias criterion is formulated from a necessary self-consistency requirement. • Error-and bias-free algorithms are required to remove mathematical and algorithmic inconsistencies. • All tested pattern-based LUCC models are formally incorrect and biased to varying levels, but Dinamica EGO is close to be error-and bias-free. • A comprehensive Land Use [and cover] Model (CLUMPY) based on error-and bias-free allocation algorithms has been developed and is freely available. • For algorithmic testing and validation-instead of spatial location validation-comparison and validation must be performed in explanatory variable space, not on maps.
allocenvmodsoft.pdf (899.07 Ko) Télécharger le fichier
hal-04301075 , version 1 (22-11-2023)
François-Rémi Mazy, Pierre-Yves Longaretti. Towards a generic theoretical framework for pattern-based LUCC modeling: Allocation revisited: Formal foundations and bias identification. Environmental Modelling and Software, 2023, 166, pp.105706. ⟨10.1016/j.envsoft.2023.105706⟩. ⟨hal-04301075⟩
15 Consultations
14 Téléchargements
