Design and study of an instrumentation and software for permanent monitoring of a cable-stayed bridge - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Permanent monitoring of the structural behavior of civil infrastructures require robust and reliable data acquisition systems. In this study, we present the dynamic monitoring of the Éric Tarbarly bridge in Nantes, France and its related acquisition system. This system enables to follow the temporal evolution of the modal parameters of the structure by storing accelerometers data, external environmental data and the associated metadata thanks to the HDF5 file format.
LATAM_SHM_2023_TT_AB_JD_full_paper.pdf (2.11 Mo) Télécharger le fichier
hal-04303006 , version 1 (23-11-2023)
Paternité
  • HAL Id : hal-04303006 , version 1
Thibaud Toullier, Arthur Bouché, Jean Dumoulin. Design and study of an instrumentation and software for permanent monitoring of a cable-stayed bridge. LATAM-SHM 2023 - 1st Latin American Workshop on Structural Health Monitoring, Dec 2023, Cartagena de Indias, Colombia. pp.1-8. ⟨hal-04303006⟩
26 Consultations
19 Téléchargements
