An original smart data sampling for wireless sensor. Application to bridge cable monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Structural health monitoring (SHM) systems often ask for a robust, flexible and costeffective solution. In that domain, since years, the technological development of Wireless Sensor Network try to be an answer. Between many other questions, one of the keypoint in wireless sensing resides in the time synchronization (e.g. how to ensure the same time base between electronic systems that doesn't know each other?). At Gustave Eiffel University, robust and deterministic solutions based on GNSS modules have already been demonstrated [1], the goal of the work presented in this paper is to go deeper into turn-key solutions by implementing and coupling this GNSS-synchronization principle into a low-power FPGA to an Analog-To-Digital converter. This hardware and software association represents a generic solution for signal sampling in a wireless manner. This work is illustrated and demonstrated by an application on the acoustic monitoring of wire-breaks in bridges cables.
IWSHM2023_SmartCan_Paper-8-final_.pdf (720.37 Ko) Télécharger le fichier
hal-04303240 , version 1 (24-11-2023)
Paternité
  • HAL Id : hal-04303240 , version 1
Vincent Le Cam, Laurent Lemarchand, Arthur Bouché, David Pallier, François Illien. An original smart data sampling for wireless sensor. Application to bridge cable monitoring. IWSHM 2023 - 14th International Workshop on Structural Health Monitoring, Sep 2023, Stanford, United States. pp.1-9. ⟨hal-04303240⟩
64 Consultations
22 Téléchargements
