aKmerBroom: Ancient oral DNA decontamination using Bloom filters on k-mer sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue iScience Année : 2023
Dental calculus samples are modeled as a mixture of DNA coming from dental plaque and contaminants. Current computational decontamination methods such as Recentrifuge and DeconSeq require either a reference database or sequenced negative controls, and therefore have limited use cases. We present a reference-free decontamination tool tailored for the removal of contaminant DNA of ancient oral sample called aKmerBroom. Our tool builds a Bloom filter of known ancient and modern oral k-mers, then scans an input set of ancient metagenomic reads using multiple passes to iteratively retain reads likely to be of oral origin. On synthetic data, aKmerBroom achieves over 89.53% sensitivity and 94.00 specificity. On real datasets, aKmerBroom shows higher read retainment (+60% on average) than other methods. We anticipate aKmerBroom will be a valuable tool for the processing of ancient oral samples as it will prevent contaminated datasets from being completely discarded in downstream analyses.
PIIS258900422302134X.pdf (2.03 Mo) Télécharger le fichier
Origine : Publication financée par une institution
Licence : CC BY - Paternité
hal-04303607 , version 1 (14-12-2023)
Paternité
Camila Duitama González, Samarth Rangavittal, Riccardo Vicedomini, Rayan Chikhi, Hugues Richard. aKmerBroom: Ancient oral DNA decontamination using Bloom filters on k-mer sets. iScience, 2023, 26 (11), pp.108057. ⟨10.1016/j.isci.2023.108057⟩. ⟨hal-04303607⟩
28 Consultations
26 Téléchargements
