Comparison of Local Weather Sensors Use versus Online Data for Outdoor Monitoring Correction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The latest improvements in infrared detectors enable the use of infrared thermography in many applications for outdoor temperature measurements through a low cost and easy to maintain solution. However, converting the radiative fluxes received by the infrared camera to the object of interests' apparent surface temperature is a challenging task. It requires us to consider the global radiative heat balance at the sensor level. Such a correction implies taking into account the background contributions (sky, sun, other elements on the scene), the involved transmissions (camera optics, atmosphere, participating media of the scene), etc. As a consequence, supplementary data are needed to achieve quantitative outdoor thermal monitoring. In this study, we propose a comparison of gathering those data from different observation scales: a local weather station, existing sensor networks such as Meteorological Aerodrome Report (METAR) and open source online satellite data from the European Copernicus program. Finally, the feasibility, advantages and limitations of the proposed methods are discussed.
AITA_2023_preprint.pdf (2.58 Mo) Télécharger le fichier
hal-04305489 , version 1 (24-11-2023)
Paternité
Thibaud Toullier, Jean Dumoulin. Comparison of Local Weather Sensors Use versus Online Data for Outdoor Monitoring Correction. AITA 2023 - 17th International Workshop on Advanced Infrared Technology and Applications, Sep 2023, Venice, Italy. pp.1-5, ⟨10.3390/engproc2023051035⟩. ⟨hal-04305489⟩
27 Consultations
8 Téléchargements
