Security Analysis of SDiTH
We show that here standard decoding algorithms for generic linear codes over a finite field can speeded up by a factor which is essentially the size of the finite field
by reducing it to a low weight codeword problem and by working in the relevant projective space. We apply this technique to SDiTH and show that the parameters of both the original
submission and the updated version fall short of meeting the security requirements asked by the NIST.
Informatique [cs]
