An Isabelle/HOL Formalization of the SCL(FOL) Calculus
We present an Isabelle/HOL formalization of Simple Clause Learning for first-order logic without equality: SCL(FOL). The main results are formal proofs of soundness, non-redundancy of learned clauses, termination, and refutational completeness. Compared to the unformalized version, the formalized calculus is simpler and more general, some results such as non-redundancy are stronger and some results such as non-subsumption are new. We found one bug in a previously published version of the SCL Backtrack rule. Compared to related formalizations, we introduce a new technique for showing termination based on non-redundant clause learning.
Logique en informatique [cs.LO]
