Extraction of vehicle behaviors at intersections - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Simulation of realistic urban environments is essential for the validation of decision-making algorithms in automated driving. To populate such spaces with independent agents that execute trajectories and that correctly interact with each other it is necessary to identify all possible behaviors that may arise from a set of real users trajectories. Using a twostep clustering process on trajectories with different duration, first on the position vector and then on the longitudinal velocity and acceleration, a number of behavior profiles can be identified per trajectory in intersections. To speed up the maneuver identification, the position clustering is executed on the dissimilarity matrix created using the dynamic time warp (DTW) measure between trajectories. As for the second clustering, the use of both longitudinal velocity and acceleration allows the representation of specific behaviors for each possible path. In both procedures the k-means clustering with DTW dissimilarity measure was used, combined with the Davies-Boudin score to define the optimal number of clusters. The final result provides the identification of behaviors in different geometric dispositions independently from map information and keeping the explainability property concerning each cluster.
itsc_final.pdf (3.77 Mo) Télécharger le fichier
hal-04314028 , version 1 (05-12-2023)
Paternité
Nelson de Moura, Fawzi Nashashibi. Extraction of vehicle behaviors at intersections. IEEE 2023 Intelligent Transportation Systems Conference, Sep 2023, Bilbao, Spain. pp.1779-1786, ⟨10.1109/ITSC57777.2023.10422152⟩. ⟨hal-04314028⟩
Collections
INRIA INRIA2
35 Consultations
37 Téléchargements
