A modular construction of type theories - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue (Article De Synthèse) Logical Methods in Computer Science Année : 2023
The lambda-Pi-calculus modulo theory is a logical framework in which many type systems can be expressed as theories. We present such a theory, the theory U, where proofs of several logical systems can be expressed. Moreover, we identify a sub-theory of U corresponding to each of these systems, and prove that, when a proof in U uses only symbols of a sub-theory, then it is a proof in that sub-theory.
2111.00543.pdf (453.01 Ko) Télécharger le fichier
hal-04317047 , version 1 (01-12-2023)
Paternité
Frédéric Blanqui, Gilles Dowek, Emilie Grienenberger, Gabriel Hondet, François Thiré. A modular construction of type theories. Logical Methods in Computer Science, 2023, 19 (1), ⟨10.46298/lmcs-19(1:12)2023⟩. ⟨hal-04317047⟩
70 Consultations
23 Téléchargements
